ekgprodco
Artwork gets rescaled when copying from InkScape
My artwork is done in InkScape.  When I copy and paste it into (or import it) into VinylMaster CUT, it scales it down just a little bit.  For example, I have a square that measures 3.5" x3.5" and when I measure it in VinylMaster it measures 3.293" x 3.293".  What would cause this?
I am new to both programs.
Thanks for your help.
Are you saving as an SVG file? VinylMaster has issues with opening them, they don't always come through correct. If you save the file as an eps then open it in VM it should come out correct.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
