jdornan 0 Posted September 3, 2019 This is more of an annoyance than a problem but when I forget it has happened its an issue. When I cut a job using the MK2 via SCALP on my MAC Pro after the job is complete it retracts the vinyl back to its original position in the machine instead of leaving it at the end of the job. Is this a function of the cutter or the software and does anyone know if I can change this behaviour? There are time I forget and send another job over and then ruin the first cut job and have to start both over again, very frustrating. Any advice is appreciated . Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 3, 2019 Hopefully in your software / cutter commands, there should be a function "Advance [x] After Cut" ? Share this post Link to post Share on other sites
jdornan 0 Posted September 3, 2019 Of course as soon as I posted I finally found the setting called "Rewind to origin - moves the blade back to the cutter's origin point " in the software settings its only available in the Pro version and on in all versions by default so you must upgrade to see it and disable it. Share this post Link to post Share on other sites
darcshadow 1,626 Posted September 3, 2019 Keep in mind though, even if you do advance after the plot you still can not send another job right away. It'll advance to the origin and start cutting over the first design. You have to be sure to hit the reset origin button after each job. 1 Share this post Link to post Share on other sites
