IamDave 3 Posted August 26, 2019 Using two of the Titan-2 28” at my work and I have a Titan-3 SE 28” at home, all are using Vinylmaster DSR V4.0. Using the Titan-2 this past week I had a 30 piece 3-layer vinyl project and each layer of the design was about 20x20 inches. One thing that would have made this project a little easier if I could figure out how the “Advance After Plot” works. This is at the bottom of the attached photo. What I think this is supposed to do is advance to the cut trough so you can make the cut. Doesn’t appear to work checked or unchecked. I have been manually advancing the X position on the Titan-2 to 120 to make the cut and then back to 15 for the next plot. The Titan-3 has a different cut trough location. Have not found any setting in Vinylmaster or in the cutter itself for the “Advance After Plot” length. I hope this is not a repeat question as I have searched through the forum and did not find a solution. Any ideas would be appreciated. Thanks, Dave Share this post Link to post Share on other sites
IamDave 3 Posted August 26, 2019 I see the checkbox adds or removes the cut line but it does not advance to the cut trough when finished. Thanks, Dave Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 26, 2019 Graphtecs only advance about an inch also after the cut.,if that. I use Flexi software. There is no place that shows how much it advances. And you cannot change the amount . Share this post Link to post Share on other sites
X1ArmBanditx 9 Posted August 26, 2019 when i have it checked it really just stops at the end instead of going back to start..it doesnt spit out enough to cut it..nope Share this post Link to post Share on other sites
IamDave 3 Posted August 26, 2019 Thanks for the information. I'm determined to figure out how to do this and I will post the fix when finished. Dave Share this post Link to post Share on other sites
X1ArmBanditx 9 Posted August 26, 2019 let us know dave! Share this post Link to post Share on other sites
KennethS 0 Posted June 10, 2021 I know it has almost been a year since the last post...but I think I found the answer. Open the vinyl spooler, and click the "Advance Method" drop down (highlighted in yellow), and then choose "Advance Gap", and set it to the desired length. n Share this post Link to post Share on other sites
haumana 1,220 Posted June 10, 2021 8 hours ago, KennethS said: I know it has almost been a year since the last post...but I think I found the answer. Open the vinyl spooler, and click the "Advance Method" drop down (highlighted in yellow), and then choose "Advance Gap", and set it to the desired length. Regardless of the age of the post, helpful contributions are always appreciated. Thank you for taking the time to post your suggestion. Share this post Link to post Share on other sites
darcshadow 1,626 Posted June 11, 2021 Agree, this is a great find, although, what version of software do you have? I just looked in mine and the Advance Gap is not an option for me. Share this post Link to post Share on other sites
