I have the letter M typed in VinylMaster Pro at 3 inch tall  When I try to cut it, it's trying to cut like 24" tall.  What is wrong, what do I need to reset?
You need to calibrate your cutter most likely. I can't remember how to calibrate the cutter in VM Pro but this video may help even though it is for the CUT version. I didn't have time to even watch the vid so if it doesn't please let me know.
I got the size part fixed.
So what happen was my cutter jammed my vinyl and the machine started beeping. I turned it off then back on and tried to work as normal. Size was off. Got that fixed.
Now new problem is It won't read registration marks. I was getting Error Code  e04017, got past that but it still won't read reg. marks so I can contuor cut.
I assume I have a setting off but don't know which one.
Any help with that would be awesome.
Also, I have had everything about 3 years. VinylMaster Pro and 8600 cutter. This is the very first problem I've had.
I am watching your video now in hopes I will spot something.
This is your error    E04017 It has exceeded detection area while detecting the registration mark. Check the media. Check the print position of the registration mark.  Move sensor closer to registration mark. Retry.     Contact Graphtec tech support.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
