I have a Graphtec FC8600-130, may cutter jammed up on some vinyl and continued beeping until I turned it off.
Now when I try to do a contour cut it won't read the Reg. Marks. I get error EO4017, I've tried resenting the machine, re-loading my VinlyMaster Pro and nothing seems
to work.  Can anyone tell me what error code EO4017 is and how to fix it.  Thank You
This is from your user manual which lists the codes. You need to figure out what caused the vinyl to jam, so it doesn't happen again.
https://static1.squarespace.com/static/5900b1a3c534a5aa8149a65c/t/592f04ae6a49634508d5ce18/1496253634544/FC8600+User+Manual.pdf
E04017 It has exceeded detection area while detecting the registration mark. Check the media. Check the print position of the registration mark.  Move sensor closer to registration mark. Retry.
