linda yang 0 Posted July 14, 2019 hi everyone: anyone here knows graphtec fc3100-120 plotter cutter. thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 14, 2019 What about it? Many people here have Graphtecs of all different models. Share this post Link to post Share on other sites
linda yang 0 Posted July 14, 2019 9 minutes ago, MZ SKEETER said: What about it? Many people here have Graphtecs of all different models. I used this machine for a lot years, suddenly I can't send data to cut due to the storm. any suggestion Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 14, 2019 Did you try a different cable? Will it still run a test cut? You should always unplug your cutter when you know it is going to storm. Share this post Link to post Share on other sites
linda yang 0 Posted July 14, 2019 14 minutes ago, MZ SKEETER said: What about it? Many people here have Graphtecs of all different models. 15 minutes ago, MZ SKEETER said: What about it? Many people here have Graphtecs of all different models. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 14, 2019 You didn't write anything. Share this post Link to post Share on other sites
linda yang 0 Posted July 14, 2019 I thought cable problem, and I will do test cut on this plotter tomorrow when I go to work thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 14, 2019 Yes, I would see if it works at all first, with the TEST feature. If not then maybe storm damaged the connector and board. Share this post Link to post Share on other sites
linda yang 0 Posted July 14, 2019 I know the local computer shop said the cable is loose, it may be the problem, the cable is 9 pin to 25 parallel, What should I do if it is board shark, it is a old machine, not tech support any more. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 14, 2019 Not much you can do if bad board. Will be hard to find. Maybe check on Ebay etc for cutter cheap. Part it out, and sell the parts. Maybe you can find a good used Graphtec in your area to get going again. Share this post Link to post Share on other sites
linda yang 0 Posted July 14, 2019 I am to buy the vevor 53" on amerzon, it is good? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 14, 2019 I already answered the question, A SC2, here on USCUTTER would be better than that cutter. https://www.uscutter.com/USCutter-SC2-Series-Vinyl-Cutter Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 14, 2019 9 minutes ago, linda yang said: thanks for help your welcome. Share this post Link to post Share on other sites
