tstone5966 0 Posted July 12, 2019 I have a Graphtec 6000-60 Plus and coreldraw 17. I have installed the cutting master 4 on my computer but when i go to launch the cut/plot (cm4) isn't an option. I need to be able to add registration marks to my file so my cutter will cut it. Help Share this post Link to post Share on other sites
Ironbar 12 Posted July 13, 2019 What exactly are you trying to cut? Vinyl or something else? I don't have a Graphtec but I have a Summa and a Roland. Both of them you have to import certain "spot" colors which translate to cut lines for the cutter. You don't need to add registration marks. Normally registration marks are used for optical recognition for cutting paper, etc. Share this post Link to post Share on other sites
haumana 1,008 Posted July 13, 2019 is your cutter physically "on" and connected to your puter? is the the first time you're trying to run the software? or you've run this setup before, and only now you're running into this problem? Share this post Link to post Share on other sites
