Kronick Designs 11 Posted June 27 This may have been asked before but I am going to cut some reflective vinyl for the first time. I am using 3M 5100 and cutting with a Laserpoint 3, i have the 60 degree blade in my machine but I'm not sure about pressure. Any advice? Thanks... Share this post Link to post Share on other sites
haumana 550 Posted June 27 You'll have to go a little heavier on the force. It will be a trial and error kind of thing. I have an original LP, and my usual pressure for colored 651 is about 88, for the reflective, I slow it down a little (from 60 to 40), and increase the pressure to 94. I haven't tried cutting reflective on my Graphtec yet, but I would probably do the same thing. Good luck. Let us know what works for you. 3 Share this post Link to post Share on other sites
ShaneGreen 123 Posted June 27 Definitely get you a "CleanCut" blade. It cuts reflective so much better. Slow down as slow as it can go and you may still have to do 2 passes. I have a LP II and have spent days testing and retesting reflective. I've finally settled on: - a 60 degree CleanCut blade, - 450g of force. "Force" seems to be pretty relative and varies from machine to machine. I cut 651 at 125g but I've seen people say they use anywhere from 50 to 200. But mine needs roughly 3 1/2 times the force to cut reflective. - a speed of 100. That's the slowest mine will go. - two passes. It will cut in one pass the majority of the time, but I cut larger decals and when it doesn't complete the cut I'm wasting a lot of time and money. - weed immediately. Reflective seems to self-heal a lot quicker than 651. - be careful of fine details. Things like the dot on the letter "i" may cause you problems staying stuck to the backing paper. - Test, test and test some more. 2 Share this post Link to post Share on other sites
haumana 550 Posted June 27 As weird as this sounds - sometimes I need the reflective to be temporary. If anyone has tried to peel off reflective, then they should know that it comes off in small pieces and is a total pain to remove. So when a temporary application is needed, I will often pre-layer the reflective on some 651 (whatever color I have the most inventory in), and then run it through the cutter, doing two passes. The end result is a pretty thick decal, but removing it is a breeze. Ditto on the Clean Cut Blade! 3 Share this post Link to post Share on other sites
ShaneGreen 123 Posted June 28 Love this idea Haumana! I just did some temporary and it was a royal pain to remove. Next time I'll use your trick! 1 Share this post Link to post Share on other sites
