MZ SKEETER 4,709 Posted June 20, 2019 4 minutes ago, klcjr said: I've already figured out that I will have to cut the material with the liner side facing down since the magnet sticks to the platen infeed and outfeed alot, didn't have that issue with the 'cheap' titan 2. In hindsight I would've told my manufacturer to roll the magnet with the magnet side facing up for easier processing. Have you tried rerolling the material back the opposite direction? And leave it like that for a bit? I do that with vinyl and hold it for about 10 minutes. It will lay flat then. Not sure how that would work with magnet. 1 Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 14 minutes ago, MZ SKEETER said: Have you tried rerolling the material back the opposite direction? And leave it like that for a bit? I do that with vinyl and hold it for about 10 minutes. It will lay flat then. Not sure how that would work with magnet. I have not, but I will keep that in mind. Ok, so I put in the blade that came with it and set the depth so that it would just scratch the surface of the magnet, and a 50x50 square is coming out as 39.64mm x 39.64mm. Not sure what I need to do to change that? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 20, 2019 Are you using SCALP? If so, which driver are you using? Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 3 minutes ago, MZ SKEETER said: Are you using SCALP? If so, which driver are you using? Yes, SCALP and, the built in one with mac, everything else is working as expected. Here's my settings: I have the step size on the machine correctly set to 2032 to match. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 20, 2019 Your showing UNITS as inches in your settings from what I see. I thought you used Metric. And you can change the steps resolution. Calibrate the cutter to the software. Nothing more I can help with SCALP. I was given a demo to try. I didn't like it all. I use Flexi software. It should not be on GP-GL Command either. That is Graphtec language. for Graphtec software. That software is HP-GL Hewlitt Packard language. Anything other than Graphtec software is HP-GL Flexi, Scalp, Signcut etc. Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 4 minutes ago, MZ SKEETER said: Your showing UNITS as inches in your settings from what I see. I thought you used Metric. And you can change the steps resolution. Calibrate the cutter to the software. Nothing more I can help with SCALP. I was given a demo to try. I didn't like it all. I use Flexi software. Yes, I changed that to be 25.4mm, but when I reopen it, it reverts back to displaying Inches. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 20, 2019 Very few SCALP people on here. Which is why UScutter changed to Vinyl Master. And only offer SCALP to a Mac user to get started. SCALP had too many problems. It was designed for craft cutters. Your tech support is at Craftedge.com Did any info come with the cutter that allows you to get the Graphtec Pro Studio or GraphtcProStudio Plus? 1 Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 When I change the calibration to the following screenshot, the 50mm square turns out correct. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 20, 2019 I won't deal with SCALP, Your on your own. Unless a Scalp person helps you out. or Craftedge. Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 Unfortunately, with the liner side facing down, I lost traction and the second pass was way off from the first one Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 20, 2019 May or may not work. Has a sticky side to it. Or Spray adhesive on paper. https://www.uscutter.com/Large-A4-Vinyl-Cutter-Carrier-Sheet-Cutting-Mat Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 I think I lost traction because I didn't pull enough off of the roll accidentally. Is there an external roller stand available to where I can mount on the wall high up and pull off let's say 7 ft (height of wall) at a time? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 20, 2019 That cutter does have Pre feed on it. Pre feed and back. It pre feeds many, many feet. I looked at mine and got to 90 ft. Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 16 minutes ago, MZ SKEETER said: That cutter does have Pre feed on it. Pre feed and back. It pre feeds many, many feet. I looked at mine and got to 90 ft. Does it put all the pre feed material in the media basket? The magnet would stick to itself. Share this post Link to post Share on other sites
haumana 1,220 Posted June 20, 2019 The machine will pre-feed, but where you direct your material to go when it's doing so is up to you. Most of us are vinyl people, so we don't have the same challenge as trying to pre-feed a really long magnetic sheet. Just know that when the pre-feed is done, it should have the same amount of slack when the machine pull is back to it's starting point. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 20, 2019 And that cutter FC will feed either direction if that helps. Back to front. or front to back. You can put the roller assembly in the front, if that would help. You could also cut 7 ft off and feed it off of a table. Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 So, I set the blade up height setting to 5mm to prevent dragging, but the blade doesnt go up to this setting before I jog, which can cause some faint scratches on the media. I'm guessing there's not a setting to keep the blade always up in this 'parked' position until I initiate a cut job. Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 I guess it does work correctly depending on what you're doing. The blade goes up 5mm (as I want) at the end of a cut job. If the blade is down when powering up the machine and then jogging, it won't go up though, which is what I'd like. Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 I tried the pre feed setting as well, and it causes the machine to report 'media too heavy' even if setting it on the Slow feed setting. Share this post Link to post Share on other sites
Kristof 4 Posted June 21, 2019 I think I might benefit from installing two additional pinch rollers in the middle; $255 each though. 1 Share this post Link to post Share on other sites
Kristof 4 Posted June 21, 2019 Is it pretty easy to install extra push rollers? I have a mechanical background. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 21, 2019 20 hours ago, klcjr said: I think I might benefit from installing two additional pinch rollers in the middle; $255 each though. I think you would definitely benefit from the extra pinch rollers. I think I mentioned that I once considered an FC machine and they last who was the rep had a 30" model that had been set up to go to a sand blast outfit who would have been cutting blast resist which is similar in thickness to magnet. They had at least one extra roller maybe two and she said it was to help feed the material straight due to the heavy pressure of that thick a cut. I was going to pull them off for what I do and just save them for replacements or something. Share this post Link to post Share on other sites
Kristof 4 Posted June 21, 2019 15 minutes ago, Wildgoose said: I think you would definitely benefit from the extra pinch rollers. I think I mentioned that I once considered an FC machine and they last who was the rep had a 30" model that had been set up to go to a sand blast outfit who would have been cutting blast resist which is similar in thickness to magnet. They had at least one extra roller maybe two and she said it was to help feed the material straight due to the heavy pressure of that thick a cut. I was going to pull them off for what I do and just save them for replacements or something. Does it look hard to install/take off the rollers? The square bar looks like it runs through both sides of the machine and it looks like it needs to be taken out. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 21, 2019 It is probably why they put 2 extra pinch roller assemblies on this 30" FC8000 that I bought. You could sure tell they were running reflective in it. No one cleaned the cutter up. It had a lot of grit on it and adhesive. Share this post Link to post Share on other sites
Kristof 4 Posted June 22, 2019 I'm having trouble locating the post where someone installed the extra rollers; I could've swore I found it on other forum before while doing my initial research of plotters. Share this post Link to post Share on other sites
