MZ SKEETER 4,709 Posted June 18, 2019 19 minutes ago, klcjr said: Ok great. By the way, here is one of the dxf files that I need to cut frequently. Can you see if it imports properly? DXF_Test.dxf Is it supposed to be this? This is on Flexidesigner 10.5 several years old. This is what I use for my design software. I have the Graphtec Pro Studio loaded on another computer. but that computer is loaded up for my FC8000 and put away. But I stay with what I have been using for years. I still only cut with the FC7000 until my son decides to buy it. Share this post Link to post Share on other sites
Kristof 4 Posted June 18, 2019 10 minutes ago, MZ SKEETER said: Is it supposed to be this? This is on Flexidesigner 10.5 several years old. This is what I use for my design software. I have the Graphtec Pro Studio loaded on another computer. but that computer is loaded up for my FC8000 and put away. But I stay with what I have been using for years. I still only cut with the FC7000 until my son decides to buy it. Yes, that image looks correct. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 18, 2019 I don't know if you run Boot Camp on your Mac or similar, but another member does and they put Graphtec Pro Studio on their Mac. Share this post Link to post Share on other sites
Kristof 4 Posted June 18, 2019 I prefer to use a Virtual machine instead of bootcamp, but yes, I could definitely go the Windows route. I have a feeling that graphtec pro studio would import the DXFs incorrectly just like the mac version does. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 18, 2019 They are not designed anything alike. Graphtec Prostudio is an fs file. not a gs file. Graphtec Pro Studio is from Flexi SAI. The same as my Flexidesigner 10.5 My Flexidesigner is Flexisign Pro with out the cutter drivers. I don't have time right now. am leaving for Post office. But I will fire that computer up after I get back. Or someone else with it can beat me to it. 1 Share this post Link to post Share on other sites
Kristof 4 Posted June 18, 2019 1 hour ago, MZ SKEETER said: They are not designed anything alike. Graphtec Prostudio is an fs file. not a gs file. Graphtec Pro Studio is from Flexi SAI. The same as my Flexidesigner 10.5 My Flexidesigner is Flexisign Pro with out the cutter drivers. I don't have time right now. am leaving for Post office. But I will fire that computer up after I get back. Or someone else with it can beat me to it. Thank you; much appreciated! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 18, 2019 It worked just fine in GraphtecProStudio. Just like it did in my Flexi software. Share this post Link to post Share on other sites
Kristof 4 Posted June 19, 2019 1 hour ago, MZ SKEETER said: It worked just fine in GraphtecProStudio. Just like it did in my Flexi software. Were the dimensions correct? Should be 300mm x 300mm square. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 19, 2019 I am set up for inches on my Flexi 11.811 x 11.811 is 300mm x 300mm I don't know too many people on here, that use metric for cutting anything in the US. US buyers understand inches, feet. Share this post Link to post Share on other sites
Kristof 4 Posted June 19, 2019 13 minutes ago, MZ SKEETER said: I am set up for inches on my Flexi 11.811 x 11.811 is 300mm x 300mm I don't know too many people on here, that use metric for cutting anything in the US. US buyers understand inches, feet. The magnet parts are for the industrial market who use the metric (preferred) system. Thank you for checking the dimensions! I can't seem to be able to install Graphtec Pro Studio on Windows for some reason: Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 19, 2019 It's got a READ Me file. Looks like AUTO run . It's been a year since mine and I was sent a download link from Graphtec with a code. I had to send my serial number to Graphtec. Your welcome 1 Share this post Link to post Share on other sites
Kristof 4 Posted June 19, 2019 Yes I see that, Autorun doesn't work when clicked upon. I don't see the readme either. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 19, 2019 I know mine came from a Cloud. What do Cloud files say? You can contact SAI. Where did you get this? Did UScutter send it to you? Both of the SAI Production 12 have READ ME files. Share this post Link to post Share on other sites
Kristof 4 Posted June 19, 2019 4 minutes ago, MZ SKEETER said: I know mine came from a Cloud. What do Cloud files say? You can contact SAI. Where did you get this? Did UScutter send it to you? I got it from Graphtec's site here: https://www.graphtecamerica.com/cp-softwares Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 19, 2019 19 minutes ago, klcjr said: I got it from Graphtec's site here: https://www.graphtecamerica.com/cp-softwares Do you have an ACTIVATION code? I believe I heard that the Activation codes are sent with your cutter. I was sent a link direct to their server at their Cloud, with a very long number and alphabet code to open it. The process for my Graphtec Pro was totally different. Mine came from here. https://www.graphtecamerica.com/cp-graphtec-pro-studio-request-form Share this post Link to post Share on other sites
Kristof 4 Posted June 19, 2019 I got the Graphtec cutter new from ebay, so looks like I'll have to try to make it work with my Sure Cuts a Lot Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 20, 2019 On 6/18/2019 at 8:31 PM, klcjr said: I got the Graphtec cutter new from ebay, so looks like I'll have to try to make it work with my Sure Cuts a Lot Just for morbid curiosity I imported the dxf into Illustrator on my mac to see what size it would come in at. Came in at 106.084 mm. I have had trouble getting files to be at the right size most of the time when using dxf file formats in Adobe. If you know the size it's supposed to be I don't see why is makes a difference. You can just upsize it to the correct dimension in any vector program. Pretty sure that all the new cutters from Graphtec can get the software for free as long as it's a modern cutter. BUT I am not a Graphtec owner so it's not in my wheel house. Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 I just received the new Graphtec; I must say the quality of the unit and packaging is miles better than the US cutter stuff 2 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 20, 2019 16 minutes ago, klcjr said: I just received the new Graphtec; I must say the quality of the unit and packaging is miles better than the US cutter stuff Great, People just don't understand how much better these cutters are built until they see for themselves. That Titan 2 to that Graphtec is night and day. This is why we brag about our Graphtecs. You really do get what you pay for. Yes, they are higher priced but they are a very high quality machine. I have owned my FC7000 since 2008 and I have never had a problem with it. NEVER!! I hope the FC8600 works out for your project. Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 24 minutes ago, MZ SKEETER said: Great, People just don't understand how much better these cutters are built until they see for themselves. That Titan 2 to that Graphtec is night and day. This is why we brag about our Graphtecs. You really do get what you pay for. Yes, they are higher priced but they are a very high quality machine. I have owned my FC7000 since 2008 and I have never had a problem with it. NEVER!! I hope the FC8600 works out for your project. Thank you; I'm still waiting on the CleanCut 60º metal blade to arrive before I will know if it works out. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 20, 2019 11 minutes ago, klcjr said: Thank you; I'm still waiting on the CleanCut 60º metal blade to arrive before I will know if it works out. Until then , learn how your cutter operates. Make sure it will work with your software. I turned my media sensor and pinch roller sensor off on day one. Media sensor measures the width of the vinyl. I don't need to measure the vinyl. The pinch rollers have magnets in them so you can't cut past them, unless you use EXPAND. I turned them off so I can cut right next to the vinyl edge. Less waste. Your welcome Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 20, 2019 45 minutes ago, klcjr said: Thank you; I'm still waiting on the CleanCut 60º metal blade to arrive before I will know if it works out. for the red blade holder correct? 1 Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 37 minutes ago, MZ SKEETER said: Until then , learn how your cutter operates. Make sure it will work with your software. I turned my media sensor and pinch roller sensor off on day one. Media sensor measures the width of the vinyl. I don't need to measure the vinyl. The pinch rollers have magnets in them so you can't cut past them, unless you use EXPAND. I turned them off so I can cut right next to the vinyl edge. Less waste. Your welcome I've already figured out that I will have to cut the material with the liner side facing down since the magnet sticks to the platen infeed and outfeed alot, didn't have that issue with the 'cheap' titan 2. In hindsight I would've told my manufacturer to roll the magnet with the magnet side facing up for easier processing. Share this post Link to post Share on other sites
Kristof 4 Posted June 20, 2019 4 minutes ago, Dakotagrafx said: for the red blade holder correct? Yes, I had to order that as well Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 20, 2019 sounds like a solid plan Share this post Link to post Share on other sites
