MrJoel 72 Posted June 10, 2019 Odd problem tonight. I sent a job through on condition 5 (my setup for reflective) and when I hit send, the plotter decided to revert to condition 1 (indoor vinyl). I tried fixing it on the control panel, then in the pc control panel program but every time I switched it, I hit send and the plotter switched it back to condition 1. I’m at a loss tonight. Whatcha think? What am I missing? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 10, 2019 Are you changing conditions from the cutter it's self or the Cutting Controller? I only run every order from my cutting controller. I do not change anything on my cutter. Never have problems. Share this post Link to post Share on other sites
MrJoel 72 Posted June 10, 2019 Trying to do it from The computer and the cutting controller program. I can update it from there and it changes on the cutter but when I hit send, it reverts back to condition 1??? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 10, 2019 Reading the user manual, when you change a condition, you are to choose the condition and push the Enter button at the same time. Operation 1 Press the [ENTER] key in READY status. CONDITION No. selection screen is displayed. Supplement It will return to state when the power is turned on when the [ORIGIN] key (RESET) is pressed. See "Setting to Default" P.3-6 . 2 Press the [1] key (No.1), the [2] key (No.2), the [3] key (No.3), the [4] key (No.4), the [▲] key (No.5), the [▼] key (No.6), the [◄] key (No.7), or the [►] key (No.8), while simultaneously pressing the [ENTER] key. P Share this post Link to post Share on other sites
