diver4 1 Posted May 21, 2019 (edited) I have read through the forum and tried every solution that was suggested with no luck. I have tried importing the image in different formats from jpg to gif and still can't get it to vectorize. I have also tried different images and have only been able to vectorize a small number of them... I have been a Sign Blazer user for a long time and even though it is still working I wanted to get a more modern version of cutting software working so I can start using that. I can import the same file into Sign Blazer and vectorize it with no problem. I have tried importing files, copying and pasting files and even acquiring them into Vinylmaster with very little luck of getting any of them to vectorize. If I export the file from Sign Blazer and import into Vinylmaster the file looks and cuts perfectly but I would like to be able to build new files in Vinylmaster using images. Any suggestions and help would greatly be appreciated. Thanks Dale Edited May 21, 2019 by diver4 misspelling Quote Share this post Link to post Share on other sites
MZ SKEETER 4,653 Posted May 21, 2019 Where did you buy your version of Vinyl Master Cut? If directly from Vinyl Master website, then it does not have the vector program in it for Vinyl Master Cut. Only the UScutter version of Vinyl Master Cut has the vector program. Quote Share this post Link to post Share on other sites
diver4 1 Posted May 21, 2019 1 minute ago, MZ SKEETER said: Where did you buy your version of Vinyl Master Cut? If directly from Vinyl Master website, then it does not have the vector program in it for Vinyl Master Cut. Only the UScutter version of Vinyl Master Cut has the vector program. It came with the new cutter I bought from US Cutter. I have been able to vectorize a small number of files with it just not all files. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,653 Posted May 21, 2019 Then it should have the vector program in it. Contact UScutter tech support or Vinyl Master tech support. Quote Share this post Link to post Share on other sites
diver4 1 Posted May 21, 2019 Just now, MZ SKEETER said: Then it should have the vector program in it. Contact UScutter tech support or Vinyl Master tech support. That will be my next step, thanks. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,653 Posted May 21, 2019 Here is a video from Vinyl Master Quote Share this post Link to post Share on other sites
diver4 1 Posted May 21, 2019 I have watched the video and am doing everything correctly and as I stated I can vectorize some images but not all. They are all black and white images like the one in the pictures I posted so there is nothing complicated about them. Thanks Quote Share this post Link to post Share on other sites
darcshadow 1,576 Posted May 21, 2019 What exactly is it that you're doing and what results are you getting? The second screen shot above looks good and you just need to click the trace button. Quote Share this post Link to post Share on other sites
skarekrow 1,841 Posted May 21, 2019 Re-Save your Original image in a Bitmap Program like Photoshop or Gimp as a .jpg with a slightly larger background so that the Black in your Example Image does not touch the outside edges of the Background. Alternately, you could remove the white background in a bitmap Program and save as a .png with a TRANSPARENT background and Trace in VinylMaster.. Then, Vector Trace. 3 Quote Share this post Link to post Share on other sites
haumana 1,165 Posted May 22, 2019 when all else fails - inkscape. 1 Quote Share this post Link to post Share on other sites
diver4 1 Posted May 22, 2019 13 hours ago, darcshadow said: What exactly is it that you're doing and what results are you getting? The second screen shot above looks good and you just need to click the trace button. Yes the second screen shot looks fine but when I hit trace the results I get are the 3rd screen shot.. Quote Share this post Link to post Share on other sites
diver4 1 Posted May 22, 2019 10 hours ago, skarekrow said: Re-Save your Original image in a Bitmap Program like Photoshop or Gimp as a .jpg with a slightly larger background so that the Black in your Example Image does not touch the outside edges of the Background. Alternately, you could remove the white background in a bitmap Program and save as a .png with a TRANSPARENT background and Trace in VinylMaster.. Then, Vector Trace. I added a small white border around the image and imported it into vinylmaster and it vectorized with no problem! THANKS!!!! Apparently if any part an image is close to or touching the edge vinylmaster does not vectorize it properly, even though other programs may vectorize it vinylmaster won't, by adding a small border around the image it worked like a champ! Thanks again skarekrow for the solution..... 1 Quote Share this post Link to post Share on other sites
Wildgoose 4,173 Posted May 22, 2019 Skarekrow saves the day! Quote Share this post Link to post Share on other sites
skarekrow 1,841 Posted May 22, 2019 Happy 2 Oblige, folks. 2 Quote Share this post Link to post Share on other sites
Guest Vinyl775 Posted January 15 When i try to vectorize then click split screen nothing appears in the second screen doesnt matter what kind of file it is i have had the mh 821 cutter for a month and havent been able to get it ti cut anything yet very frustrating I watch the tutorials over and over and dont even get the same options in my program which came with the cutter from us cutter Quote Share this post Link to post Share on other sites
slice&dice 2,367 Posted January 15 Vinyl775, welcome. May I make a small suggestion? Try using a different program, just to get a feel of your cutter operating correctly, and then move beyond the basics into other options. Here is the most simple application to connect and run the MH unit --http://www.uscuttersupport.com/downloads/Software/SignBlazer/signblazer_setup.exe (Choose RedSail RS720C in Cutter setup) When you have it installed and open, go to the DRAW menu, choose Library, and pick any graphic from there. Let's start with that. Quote Share this post Link to post Share on other sites
darcshadow 1,576 Posted January 17 What version of Vinyl Master do you have, I believe Cut is the default version that is included which is extremely limited on what it can do. Basically it can cut. Any design work would need to be done in another program. Inkscape is good for that, and it's free. 1 Quote Share this post Link to post Share on other sites
Guest Tania Posted May 12 Thanks for the confirmation. Was starting to think I was going crazy! Have messaged them already and waiting on a reply. Quote Share this post Link to post Share on other sites
