mad1577 0 Posted May 12, 2019 Having an issue with my cutter not completing a cut. I'm running sure cuts a lot 3 pro. Screen shot is what I sent to the cutter, and the pic is what I end up withIt will cut fine, then jump around to random shapes, then go home without finishing. File to large? (Don't mind the flipped image). Thanks in advance. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 12, 2019 the refine series has a very very small onboard memory - file could just be too big Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 12, 2019 For troubleshooting this problem, highly suggest using SignBlazer cut program (MH driver is RedSail). http://www.uscuttersupport.com/downloads/Software/SignBlazer/signblazer_setup.exe Share this post Link to post Share on other sites
darcshadow 1,625 Posted May 13, 2019 Have you grounded the stand/vinyl? Could be a static issue. Share this post Link to post Share on other sites
