Pebbles1488 6 Posted April 18, 2019 Hello everyone! I gave in and finally switched over from Sign Blazers to VinylMaster Ltr V4.0. I want to cut my decal, I set the vinyl where I want it in the cutter, then I press cut and it spits the vinyl backwards and then cuts on the machine because the vinyl is out the backside. HOW do I turn this feature off and make it cut right where I set it? AND.....I calibrated it already, and it's cutting letters on top of eachother. Quote Share this post Link to post Share on other sites
darcshadow 1,625 Posted April 18, 2019 Are you setting the origin point on your plotter? Quote Share this post Link to post Share on other sites
Pebbles1488 6 Posted April 19, 2019 I pressed reset and origin before I cut. Do I need to do something else too? Quote Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 19, 2019 I reached out to vinylmaster - hopefully they will be along shortly Quote Share this post Link to post Share on other sites
Pebbles1488 6 Posted April 19, 2019 THANK YOU so much!!! Quote Share this post Link to post Share on other sites
