nrkoucky 0 Posted April 15, 2019 What size blade should I use then cutting cardstock on a carrier sheet? Also same question for scraps of vinyl. Share this post Link to post Share on other sites
darcshadow 1,626 Posted April 15, 2019 If by size you mean angle, I believe a 45 degree blade is the recommended blade for cardstock although 60 will work as well, will just probably dull a bit faster. If by how much blade is sticking out, follow the standard blade length setting procedures posted by Mz Skeeter a gazillion times on here. Share this post Link to post Share on other sites
