talibulelm 1 Posted April 3, 2019 Hi, I have a MH series have not used it in a long time due to work. Now i am free and wanna get it going. I will be using windows 10, not sure how that's going to work but anyway. I have a Keyspan US 19HS I see there is another keyspan out there should I change to that since ports are different nowadays. I See there is a Signcut M cut for $59 and also and a vinyl subscription for $9.99 , how do i know which to get. Since it use to stop during cut do I need memory for that or whatever.Any suggestions would help alot . Thanks , Share this post Link to post Share on other sites
slice&dice 2,450 Posted April 4, 2019 Hey buddy, you can run that machine using (abandonware) SignBlazer and RedSail driver. Your computer and the cutter may just work with USB, ya neva know! 1 Share this post Link to post Share on other sites
haumana 1,220 Posted April 4, 2019 7 minutes ago, slice&dice said: Hey buddy, you can run that machine using (abandonware) SignBlazer and RedSail driver. Your computer and the cutter may just work with USB, ya neva know! I'd definitely give that a try before diving into a keyspan. 1 Share this post Link to post Share on other sites
talibulelm 1 Posted April 4, 2019 Thanks for responding , slice&dice and haumana ! oh really, where can I find signblazer or redsail. Is there anyway to stop it from freezing during cut? Thanks Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 4, 2019 right here. 1 Share this post Link to post Share on other sites
talibulelm 1 Posted April 4, 2019 Thank Mz Skeeter! Any suggestions on memory , I remember that it would freeze during cut Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 4, 2019 There is nothing you can do about the memory. (I don't think they sell the memory upgrades anymore) That cutter is a bottom of the barrel vinyl cutter with very limited memory. If you want good memory buy a better vinyl cutter. 1 Share this post Link to post Share on other sites
haumana 1,220 Posted April 4, 2019 If you're cutting multiples of a design, then what you can do is to break it into batches, so less data is being sent to the machine. If it's a huge design, then take a look at how many nodes it has, and if it can be cleaned up a little more - re-save the artwork, re-import it, and see where that gets you. 1 Share this post Link to post Share on other sites
talibulelm 1 Posted April 4, 2019 Thanks for the link, I will check it out Share this post Link to post Share on other sites
