KaylaL 0 Posted March 20, 2019 Hey all! Co-worker brought in his cutter for us to use at the shop and I am having a hell of a time trying to figure it all out. I have downloaded the signblazer on my main computer and a laptop and the file will not pull up at all. I have converted it to an eps, ai, jpg, tiff and dxf and nothing is working. At first it would pull up the image but couldn't go to the cutter due to the bitmap in the image. downloaded inkscape to vectorize it with no bitmaps and still noting. Got the Adobe illustrator installed and saved the file like that and still nothing just a black box. I have tried transferring the file by just clicking on it and dragging it over and still NOTHING!! I have watched all the Youtube videos that are in English and searched here but can't seem to find what is wrong. Please help because I'm ready to blow it all up! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 20, 2019 No mention of which cutter. That makes a big difference. Signblazer has not been updated for many years, and it will not be as the owner passed away years ago. Can only use older version of files like version 8 .eps Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 20, 2019 Have you tried just basic shapes and text that you create within SB? Need to figure out is this a cutter/software issue, or just an image issue. JPG and Tiff are raster image formats and can not be cut. EPS and AI are vector formats, but they can also contain raster images, which sounds like you've figure out already. 1 Share this post Link to post Share on other sites
KaylaL 0 Posted March 20, 2019 This is on the side of the cutter. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 20, 2019 Did you set up the cutter to use on Signblazer, download the drivers etc. Match the com port number in the computer device manager to the com port number in Signblazer? Do like Darcshadow says, just do some text or shapes and make sure it is connected properly. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 20, 2019 did you vectorize the image or just try to convert it - huge difference and I think where everyone is heading Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 20, 2019 why not have the co worker set the cutter up? it is their cutter. 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 20, 2019 Well, looking at the image posted above, my first suggestion would be "plug it in" (no power cord attached in the picture!!!!!) 4 Share this post Link to post Share on other sites
KaylaL 0 Posted March 20, 2019 it is plugged in and that is not the problem. The image on the import screen is just a black screen. Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 20, 2019 Did you actually try to open them? The preview screen does not always work, and I'm not sure it shows previews for anything other than sbd files anyway. 1 Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 20, 2019 I just check, and on mine anyway, EPS files do not have a preview, they are just black but import just fine. Share this post Link to post Share on other sites
KaylaL 0 Posted March 20, 2019 1 minute ago, darcshadow said: Did you actually try to open them? The preview screen does not always work, and I'm not sure it shows previews for anything other than sbd files anyway. yes i have and nothing is loading at all. I tried opening it as full postscript interpreter and postscript scanner and nothing shows up. I go to the cutter view and there is nothing there. Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 20, 2019 If you can, post the vector file and I'll try to open it. Share this post Link to post Share on other sites
KaylaL 0 Posted March 20, 2019 1 minute ago, darcshadow said: If you can, post the vector file and I'll try to open it. JDP_LOGO1.ai Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 20, 2019 see if this ,eps file works There is a line on each side of the logo, not sure if they are supposed to be there. JDP_LOGO1.eps Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 20, 2019 What version of AI file is that? I can't open it in SB, but I could open in in VM and Inkscape. I then converted it to EPS and it imported just fine in SB. SB is OLD and you have to use the old version of ai files as well as eps files. Share this post Link to post Share on other sites
KaylaL 0 Posted March 20, 2019 11 minutes ago, MZ SKEETER said: see if this ,eps file works There is a line on each side of the logo, not sure if they are supposed to be there. JDP_LOGO1.eps Tried the file and it still isnt showing up. 11 minutes ago, darcshadow said: What version of AI file is that? I can't open it in SB, but I could open in in VM and Inkscape. I then converted it to EPS and it imported just fine in SB. SB is OLD and you have to use the old version of ai files as well as eps files. How do I get it to save as an older version? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 20, 2019 Are you opening or importing the files.? I thought you had to import to SB. I could be wrong. I don't really use it, just have it on my computer. I have converted files before for people with SB and they were able to import them. Share this post Link to post Share on other sites
KaylaL 0 Posted March 20, 2019 2 minutes ago, MZ SKEETER said: Are you opening or importing the files.? I thought you had to import to SB. I could be wrong. Both! No dice Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 20, 2019 9 minutes ago, KaylaL said: Tried the file and it still isnt showing up. How do I get it to save as an older version? When you go to SAVE AS, .ai should give you options to save in different versions. Search online for your version and see how to do it. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted March 20, 2019 Here is a legacy version 8 eps file saved from Illustrator. The lines on the side were removed. Between Skeeters and that one you can rest assured it is not the file. Something else. JDP_LOGO1b.eps Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 20, 2019 Ms Skeeter is correct, SB can only "open" SB files, all others have to be imported. I tried opening her EPS and I got the same as you, just a blank screen. Wildgoose's file import just fine. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 20, 2019 4 minutes ago, darcshadow said: Ms Skeeter is correct, SB can only "open" SB files, all others have to be imported. I tried opening her EPS and I got the same as you, just a blank screen. Wildgoose's file import just fine. I exported the file from Flexidesigner10. as an .eps. I didn't make any changes to it. Share this post Link to post Share on other sites
kctrader 10 Posted March 21, 2019 2 hours ago, MZ SKEETER said: I exported the file from Flexidesigner10. as an .eps. I didn't make any changes to it. I had the same results. Wildgoose's version opened fine and cut. 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 21, 2019 1 minute ago, kctrader said: I had the same results. Wildgoose's version opened fine and cut. Maybe my .eps version is too new of a version for SB, 1 Share this post Link to post Share on other sites
