Joseluis 0 Posted March 19, 2019 Good day, I'm having problem with my plotter mh721 mk2, when I turn it on it make a sound like stuck and if i push it it start to move and do the process, and when I send something to cut it cut it really bad Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 19, 2019 Welcome from the USA, First give us a little history, is this a new plotter? If used when did it last make a good cut? What OS and cutting software are you using? Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 20, 2019 15 hours ago, Joseluis said: Good day, I'm having problem with my plotter mh721 mk2, when I turn it on it make a sound like stuck and if i push it it start to move and do the process, and when I send something to cut it cut it really bad Grinding noise? This seems to be a symptom of motherboard failure, as reported several times in these forums by others who experienced this same terrible sound. Share this post Link to post Share on other sites
darcshadow 1,625 Posted March 20, 2019 Is the carriage seated properly on the rail? Is the belt slipping? Sounds to me like something is simply preventing the cutting head from moving freely. The grinding noise is typically a result of the motor turning, but the belt not moving. Share this post Link to post Share on other sites
