MZ SKEETER 4,708 Posted March 14, 2019 Then save your pictures and call Graphtec. They are your tech support. Share this post Link to post Share on other sites
scottbaggerly 0 Posted March 14, 2019 Just now, MZ SKEETER said: Then save your pictures and call Graphtec. ok thanks Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 14, 2019 4 minutes ago, scottbaggerly said: ok thanks Or try a different version of the Graphtec software. like Cutting Master. Or try Signblazer Trials of Vinyl Master, Signcut,, Your welcome. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 14, 2019 where it says JOB SIZE, why do you have 382.074 %? (hard to read the screen shot) It should be 100% All of mine are, and so is Dakota above. 1 Share this post Link to post Share on other sites
haumana 1,220 Posted March 14, 2019 Okay. So now that we know that the job size is over 3x bigger than it should be (in your cutter settings). Go back to the design window and get your graphic to be the actual size you need it to be. If your design 'area' is too small, then you need to make it bigger. It's usually a good idea to maybe have it set to the width of the vinyl. Then try the cut again. Share this post Link to post Share on other sites
