leahlhart24 0 Posted March 1, 2019 I just purchased the MH 721 and I am wondering if anyone knows if it will cut plastic stencil material that is .03 inches thick. If so, does anyone know what the setting for the blade should be set at? Thanks for the help. Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 1, 2019 I would say "no" 1 Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 1, 2019 I would say no as well, not sure the blade would even be big enough and if it is, it would not be able to do the pressure required to cut something that thick. It might be possible if you do 2 or 3 passes, but I would not count on the accuracy of the MH to be consistent enough to exactly trace the same path. Share this post Link to post Share on other sites
