firefighter698 0 Posted February 17, 2019 I bought a new computer and installed my VinylMaster LTR, when I go to the spooler the cutfiles that were on my old system aren't there. Where do I find them on the old computer and where do I copy them to on the new system. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 17, 2019 what is the file extension for Vinyl Master files? You should be able to do a search of your computer, for all of the files extensions. I don't use VM. but my files are in my documents, or downloads, different file extensions. if you search .eps files all files should show up etc. Depending on how many files you have. You can put them on flash drive, external hard drive, or transfer sata to sata. I have done that before. But regardless, you should have already had all of these files backed up somewhere off of your computer. To be able to access, if your computer crashes. Even the fonts that you have downloaded. If your going to run a business or even a hobby, you need to be backing your files up. If I even do something new, As well as saving elsewhere. I also drop it into an email draft and I can access it from anywhere. Quote Share this post Link to post Share on other sites
darcshadow 1,625 Posted February 18, 2019 I'm not sure what is in the spooler are actual files. I believe the program stores that info in a database type system. It'd be best to not depend on the spooler history and just load your vinyl master file and send it to the cutter. 2 Quote Share this post Link to post Share on other sites
