mickt 0 Posted February 2, 2019 hi can any one help me I have the mh721 and it keeps leaving nicks like in the attachment.any ideas why its doing this mick Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 2, 2019 You don't give enough info to help you. No mention of how you set your blade depth, which cutting software, what is your blade offset. What computer system? How fast are you running the cutter? How is it connected to the cutter? What type of vinyl? This is info that you need to provide to get help. That is a bottom of the barrel vinyl cutter, that is going to take a lot of fine tuning to get it to cut good. We always tell buyers to not buy that cutter. Any cutter up from that would have been better. That cutter has many known problems. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 2, 2019 if your software has it add to the OVRECUT - don't mess with the offset though - too many people don't understand offset and make that mistake and from what little I can see your offset looks good so look for overcut as it helps with the limitations of the value cutters 1 Share this post Link to post Share on other sites
