vino 0 Posted January 28, 2019 why does my pcut cto630 canot make a perfect circle, it does a circle but its like distorted.. what should i do.. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 28, 2019 are you pre feeding your vinyl - Welcome from the USA Share this post Link to post Share on other sites
vino 0 Posted January 29, 2019 yes..when i cut 1*1 inches of circle it become distorted...please help me with the problem Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 29, 2019 what cutting software are you using? Share this post Link to post Share on other sites
vino 0 Posted January 29, 2019 signzworld ver.1.3 beta23 Share this post Link to post Share on other sites
haumana 1,220 Posted January 29, 2019 what is the size of the vinyl you're feeding into the machine? is there a chance that it's too small and it's have traction/movement issues? Share this post Link to post Share on other sites
darcshadow 1,625 Posted January 29, 2019 How about if you cut a 1" square, is it exactly 1" on each side? Share this post Link to post Share on other sites
vino 0 Posted January 30, 2019 2*4 inches vinyl..theres no problem when i cut square only in circle.. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 30, 2019 That is pretty small piece to cut from, maybe slipping? Are you using the absolute least blade exposure possible? Maybe think about using a cutting mat for scraps that small? 2 Share this post Link to post Share on other sites
haumana 1,220 Posted January 30, 2019 4 hours ago, Dakotagrafx said: That is pretty small piece to cut from, maybe slipping? Are you using the absolute least blade exposure possible? Maybe think about using a cutting mat for scraps that small? that's what I was thinking. if you don't have a cutting mat, try it on a larger piece of vinyl, it's not like you need to cut a circle in the middle of the piece, just cut it on the corner - but a larger piece might give you way better traction. especially if it's big enough to use 2 pinch rollers and has wiggle room to spool a little back and forth. Share this post Link to post Share on other sites
vino 0 Posted January 30, 2019 no i dont cut it from that small piece..i insert a 2 ft.* 4ft of vinyl then the size of circle that i cut is 1*1 inches.. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 30, 2019 How are you making the circle? Are you just using the circle tool? How did you set your blade depth? Vinyl cutting only takes the very tip of the blade to cut. You should just see and feel the very tip of the blade out of the blade holder. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 31, 2019 Can you post a picture of a 1 inch square and a 1 inch circle both cut side by side so we can see the details? Share this post Link to post Share on other sites
