Rgonzalez0410 0 Posted January 28, 2019 I replaced the old blade with a new blade and the new blade is not making a clean cut of the design. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 28, 2019 I hope you reset the blade correctly. This is how. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. You should just barely see and feel the blade tip out of the blade holder. Share this post Link to post Share on other sites
