mattgirard
Gaphtec Stuido/ Graphtec Pro Stuido
Does anyone know if I can convert files from Graphtec Stuido  (.gstudio) to Graphtec Pro Studio (.FS or .PD)? I have a Graphtec CE600-40 Plus. I can cut with Graphtec on my Mac but apparently this cutter will only work with Graphtec Pro Stuido on PC.  Ive tried to convert the original Graphtec files to pdf or jpeg and open them in pro studio, but the quality gets decreased for some reason.  Any help is appreciated, thanks.
that cutter works on a pc with most cutting softwares as the graphtec is the most popular cutter sold.    you need to "export" your file in a vector format like .eps and then import it on the other computer
The Graphtec Pro Studio is only a PC program.   It was created by SAI as a rebranded Flexi product for Graphtec.   I have taken files and changed the file extension to .fs and they have imported before.  Try it on one of your files.  Go into your documents where you can see the file. Right click the file.   rename it with the extension .fs  See if you can import it.  I would save the file first so that you have the original.   Otherwise,  you will have to export the file like said above, or recreate the file.
Ok ill try that. Im not transferring from one computer to another.  I created designs on my PC on Graphtec but could not cut them.  So I had to download pro studio, just didn't want to have to recreate my designs.
Are you referring to the Graphtec Pro Studio that Graphtec requires you to send in your serial number from your vinyl cutter  to get?  Then they send you the code and download?   Or something else?   According to Graphtec, request form,  this software is not available for CE6000  PLUS vinyl cutters.
This one?   https://www.graphtecamerica.com/cp-graphtec-pro-studio-request-form/
No I have the serial number and everything.  I just have some designs that were created on my PC on Graphtec Studio, but I can only cut on my PC with Studio Pro, not the basic Graphtec studio software.  I just don't want to have to re create these designs in Studio Pro since I am more familiar with the basic version. I can cut just fine on my PC with the pro version, just wanted to convert the files over to be compatible with pro.
or other program
you can lead a horse to water . . .  but if they don't want to follow the directions . . . .
