ricardombalanonjr 0 Posted January 3, 2019 Hello, I recently revived my Cuyi Vinyl Cutter CTO630 and tried the demo version of signmaster. My problem is it is not showing in 'Current Cutter' in Vinyl Spooler tab. My laptop can detect it as COM 6. I did a test on baudrate tab to detect my cutter and the cutter responded. I am attaching pictures so you can see what I did. Anything I missed? Looking for answers. Any help will be really appreciated. Regards, Ric Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 3, 2019 Did you reboot your computer after installing everything? Is the device manager also matching Com 6? It must. Share this post Link to post Share on other sites
ricardombalanonjr 0 Posted January 4, 2019 I tried rebooting it twice. Yes, it matched com 6. In the first picture, I was able to connect my laptop to the cutter. Is there anything I missed? You just install a driver for the cutter and use a software for cutting e.g signmaster, make sure the coms and baudrate matches and that is it right? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 4, 2019 That cutter is more than likely a Creation Pcut CTO630, Did you add the cutter? Look in the drop down box for the cutter and add it. You have listed Current cutter some Generic S(cannot read it) Cutter Share this post Link to post Share on other sites
ricardombalanonjr 0 Posted January 4, 2019 There is nothing in the drop down box. I can't add it, its empty. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 4, 2019 I don't know where you got that Sign Master, but it kinda looks like Vinyl Master, When you go to the SET UP Wizard there are hundreds of different vinyl cutters to choose from in the drop down boxes. No one here uses Sign Master. Go to their support and ask for help. Share this post Link to post Share on other sites
ricardombalanonjr 0 Posted January 4, 2019 Thank you sir for the replies. Really appreciate it. Will do that. Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 4, 2019 Years ago, I recall reading that cutters should be operated in Com 1 to 4 only. Not sure why that is, but try changing the Port in your Windows Control Panel -- Devices -- properties to a lower number than 6. (1-4) Share this post Link to post Share on other sites
ShaneGreen 131 Posted January 4, 2019 I'm with Mz Skeeter on this one. The error box even says "CutspoolerVM3.exe." VM3 as in VinylMaster Version 3. The layout of the pages looks just like a stripped down version of VinylMaster. Well what do you know? Went over to the Signmaster website and it's owned by Future Corp, the same folks who own Vinylmaster. I learned something new today and it's not even noon yet! Share this post Link to post Share on other sites
nicnicnic 0 Posted February 24, 2021 Did you figure out how to fix your problem. I'm struggling with the drop-down being empty as well. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 24, 2021 That cutter is very similar to a Refine or a Redsail, try one of those brands, Com port number must be between 1-4. On the screen on the right it says + ADD, So add your cutter. Share this post Link to post Share on other sites
nicnicnic 0 Posted February 24, 2021 tried that, but my drop down still wont let me select any type of cutter, or rather it doesn't show any cutters Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 25, 2021 so where did you get your software? Contact Vinyl Master tech support. No one here can help with that. Share this post Link to post Share on other sites
nicnicnic 0 Posted February 25, 2021 Came with the cutter. Signmaster. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 25, 2021 Signmaster is sold by Vinyl Master. Contact tech support. Did you download and install the driver? You must. https://www.vinylmastercut.com/support/ Share this post Link to post Share on other sites
