MrJoel
Setting for tool holder going higher between cuts
Ok yall, I am cutting some fairly thick material that i used to do on my titan.  it comes in at 22mil and both machines are cutting it fine.  the problem is that the Graphtec doesn't raise the blade high enough between cuts.  I know I've seen somewhere that the advanced settings has a spot for raising the blade higher after a cut but I can't find it.  hopefully it is available through the plotter controller as I am still without my #1 button.  Thanks in advance
