scharamut 0 Posted December 6, 2018 I am fairly new to this and I am trying to use the forever paper to add artwork to some 30 oz tumblers. I am not able to find any info on how to do this. I am curious as to what temp should be, how much pressure i should apply with silicone wrap, and how long? I have tried several temps i have been kinda guessing at...I have had good results but very difficult removing paper. any suggestions would be appreciated Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 6, 2018 If you do a search online, there is a chart for using it, temps, time, material, press, printer etc. I cannot post it here. I found it pretty easy. It is a PDF 1 Share this post Link to post Share on other sites
scharamut 0 Posted December 6, 2018 I have them, just doesnt seem to apply to 30 Oz tumblers. 3 minutes at 390 in an oven seems to bind the paper to the tumblers. had to spend 20 minute+ to try and remove paper and ends up damaging artwork because does not release easily. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 6, 2018 maybe someone else can help. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 6, 2018 48 minutes ago, scharamut said: I have them, just doesnt seem to apply to 30 Oz tumblers. 3 minutes at 390 in an oven seems to bind the paper to the tumblers. had to spend 20 minute+ to try and remove paper and ends up damaging artwork because does not release easily. That appears to be different time and temp from the instuctions posted on the uscutter info page. https://www.uscutter.com/static/PDFs/Forever-Multi-Trans-Mugs-Hard-Surface.pdf Share this post Link to post Share on other sites
scharamut 0 Posted December 6, 2018 those are different then the one i recieved too. so do i go with the ceramic mug times (284 degrees for 3 mins) or the ALUMINIUM (250 for 60 seconds) because the tumblers are stailess steel not aluminum Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 6, 2018 1 minute ago, scharamut said: those are different then the one i recieved too. so do i go with the ceramic mug times (284 degrees for 3 mins) or the ALUMINIUM (250 for 60 seconds) because the tumblers are stailess steel not aluminum I’ve never used it so I would suggest calling support ( from someone else that probably hasn’t used) it but should have the info from the manufacturer at their disposal Share this post Link to post Share on other sites
darcshadow 1,626 Posted December 6, 2018 Just a guess but I'd go with the aluminium setting to start with and adjust from there. My guess is you'll need to increase the temp and time a little as aluminium will transfer heat faster than stainless steel. Share this post Link to post Share on other sites
scharamut 0 Posted December 6, 2018 I appreciate the help. ill let you know what i find out Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 6, 2018 We appreciate that, feedback after solving a problem is what makes the forum great for searching problems others have had. Helps everyone in the future Share this post Link to post Share on other sites
Lesli Shambly 0 Posted April 20, 2019 Thanks for help. Share this post Link to post Share on other sites
