Dekrahl 2 Posted December 3, 2018 Any ideas why it is doing this? I have adjusted the pressure as high as I can and it still does it. I got hit in the face with it once and it busted my lip and put a dent in the wall behind it... any advice would be appreciated Share this post Link to post Share on other sites
bikemike 711 Posted December 3, 2018 Over center setting. Should be on the handle near the top platen. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 3, 2018 PS spamming this all over the forum will just cause all but one to be deleted - most regular member watch all new post Share this post Link to post Share on other sites
Wildgoose 4,200 Posted December 4, 2018 Post a pic it might help too. Some of the cheaper presses have weak pins and they wear out relatively quickly if not lubed well. If yours are worn it could effect the over center ability to the point it won't allow it to lock again. I have heard of people drilling the pin holes out and installing larger ones to get a tight fit again. Share this post Link to post Share on other sites
Dekrahl 2 Posted December 19, 2018 I will post a picture tonight. Not sure what over center is? Share this post Link to post Share on other sites
Dekrahl 2 Posted January 1, 2019 Okay sorry it took a while for me to post pics... I can see on one side of the part that hold the arm to the top plate where it looks like the other end of the bolt thing is missing. Could this be what I am looking for? Any ideas on how to fix? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 1, 2019 looks like 1/2 of a specialized shoulder bolt is missing - I would call support to see if they have any Share this post Link to post Share on other sites
Dekrahl 2 Posted January 1, 2019 Well I picked the press up to mow it and found the miss bolt. I am putting it back on now to see if that fixes the issue 2 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 1, 2019 even better because you know you have the right one that way! 1 Share this post Link to post Share on other sites
darcshadow 1,625 Posted January 3, 2019 On 1/1/2019 at 12:08 PM, Dekrahl said: Well I picked the press up to mow it ... Curious, what sort of grass grows on your press? 3 Share this post Link to post Share on other sites
