Guest Nancy Posted December 3, 2018 I have a JPEG image that is a total of 72" long (Growth Chart Ruler Markings and numbers) I need to be able to cut it into smaller sections so that it will fit my vinyl which is 48" long. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted December 3, 2018 You cannot cut jpeg images. The design must be a vector file. If you had the file in a vector, you could separate it. 2 Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted December 3, 2018 You can't cut a JPEG. You will need to vector it, although if it's just ruler markings and numbers it'd be easier to just remake it in your vector program. Once you have the design as a vector you can easily cut it up into smaller sections to fit your vinyl. 2 Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted December 5, 2018 If you have PRO or above you can draw a square over the parts of the jpeg you wish to cut out, select both items and hit Punch out from the Weld Tools. Works the same for bitmaps as it does vectors: Punch Out - Quick Lesson 1 Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted December 5, 2018 Your can also use the Node edit tools on bitmaps i.e. modify the shape and if you have PRO or above click the Images (menu) > Edit Pixels Quote Share this post Link to post Share on other sites
