allwrappedupip@gmail.com 0 Posted November 30, 2018 I have an MH-721 and we have an area cut out that keeps getting caught on all the decorative grooves and the area around the roller bar. I've been able to place tape over most of it to fix it from catching all the time, but where the tape stops around the roller bar it eventually lifts up and catches the paper destroying everything. Where can I find disassembly instructions for my cutter so I can wrap my tape inside next to roller where it will no longer be able to get caught? Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 30, 2018 The MH Cutters are easy to take apart. Just remove the phillips screws holding the bottom on, and you'll have access to the grit rollers. Share this post Link to post Share on other sites
darcshadow 1,625 Posted December 3, 2018 What are you cutting that is getting caught on anything? Once the vinyl is fed in there shouldn't be anything to snag on the cutter. The vinyl backing should be nice and smooth. Share this post Link to post Share on other sites
haumana 1,220 Posted December 3, 2018 picture(s) would be helpful. if the front edge of your vinyl is getting caught in the cut-out that the roller are in, then you need to feed the vinyl more forward when starting. Share this post Link to post Share on other sites
