MaggieC 0 Posted November 29, 2018 I would like to cut fabric like the brother scan and cut do I need a special blade I tried using a mat and I put some fusible backing on the material but I cant get it to cut it. Has anyone tried or done this? Share this post Link to post Share on other sites
haumana 984 Posted November 29, 2018 define, "Can't get it to cut" What's happening? Is the carriage not running? is the it going, but the blade isn't cutting through the fabric? is the fabric bunching up? post pics if you need to. 1 Share this post Link to post Share on other sites
darcshadow 1,368 Posted November 29, 2018 The brother machine uses a fabric blade and a high tach cutting mat, so I don't believe you'd be able to cut fabric using your machine. HOWEVER, I did find a youtube video of a lady explaining how to cut without using a fabric blade or a cutting mat. She used two sheets of freezer paper to sandwich the fabric and then cut it with a normal blade. Might give that a try. 2 Share this post Link to post Share on other sites
