ScrantonStrangler 3 Posted November 26, 2018 Recently I decided I wanted to try something pretty complex. It’s a design I made that consists of 3 colors. I managed to get them lined up pretty damn well but when I went to apply it I got a crap ton of bubbles. I’m assuming it’s becasue I used a large solid piece for a background layer and put the other layers over it instead of cutting the background layer to fit the other layers in it. Is there any way around that? When I try to cut the layers exact, I don’t think my cutter(or maybe my program) can be that precise and I end up about a mm off even tho I’m dead on the registration marks. Another question about registration marks, should they be a certain size/shape? Thanks in advance! Share this post Link to post Share on other sites
Wildgoose 3,746 Posted November 26, 2018 You did it correctly. The bubbles come from the install. Sorry to tell you that but it's only lack of experience with the squeegee or you pre-stacked the design prior to installing it on the final substrate. If the later was the case there isn't much you dan do because the bubbles come from the difference in thickness at each layer. There are some installation tips in the Instructional Contribution Section of the forum that might help you. 1 Share this post Link to post Share on other sites
ScrantonStrangler 3 Posted November 26, 2018 I did stack them all to create one large decal. Should I apply each layer right to the surface itself? Every layering video I watched showed people layering the vinyl onto a final piece of backing paper and ending up with finished decal ready to go. Is it not possible to stack them and say send them off to someone who purchased? Thanks 53 minutes ago, Wildgoose said: You did it correctly. The bubbles come from the install. Sorry to tell you that but it's only lack of experience with the squeegee or you pre-stacked the design prior to installing it on the final substrate. If the later was the case there isn't much you dan do because the bubbles come from the difference in thickness at each layer. There are some installation tips in the Instructional Contribution Section of the forum that might help you. Share this post Link to post Share on other sites
bikemike 605 Posted November 26, 2018 You can stack to make 1, but it takes a lot of practice. Always better to assemble at the final resting place. Share this post Link to post Share on other sites
ScrantonStrangler 3 Posted November 26, 2018 20 minutes ago, bikemike said: You can stack to make 1, but it takes a lot of practice. Always better to assemble at the final resting place. hmm ok good to know. I was going to try to make these to sell but I don't know if people would want to/be able to do that. I have people who rip their decals all the time because they didn't read the instructions I send with them lol I was kind of guessing that when peeling off the app tape it would create problems. Would a low tack tape help? Share this post Link to post Share on other sites
bikemike 605 Posted November 26, 2018 Even if you perfect layering, the buyer would probably get bubbles installing it due to the varying thickness. Personally, I would sell them as separate pieces with instructions and let them do it right. (if they read the instructions) 1 Share this post Link to post Share on other sites
Wildgoose 3,746 Posted November 27, 2018 8 hours ago, ScrantonStrangler said: hmm ok good to know. I was going to try to make these to sell but I don't know if people would want to/be able to do that. I have people who rip their decals all the time because they didn't read the instructions I send with them lol I was kind of guessing that when peeling off the app tape it would create problems. Would a low tack tape help? Tough call on how to market them. You are correct that the end user may mess them up either way. I have always struggled with pre-layered work getting bubbles long the layers. The tape pushes down and basically stretches the lower layer slightly when it's getting installed or at least that's my take on the WHY it happens. If I were selling them I would probably pre-layer them and give as explicit instructions as possible to apply from one side in a hinge method and use a squeegee if possible. Maybe an upsell option to sell a squeegee along with it and then instruct the that if they choose not to use a good squeegee they can try to use a credit card. In the end the ones that didn't buy the squeegee can at least be told they probably should have. A pin to pop the bubbles the best they can and the rest will usually work their way out over time. I had one side window I did on my own business rig when I was brand new. Had literally a thousand tiny bubbles from my inexperience. A few weeks later after some sun expansion and contraction and they were all gone. The only other really solid cure might be to do the bottom layer in an air release variant if you can get the right color. They are usually thicker vinyl but have little air vents built into the adhesive and allow you to chase the bubbles out pretty good most of the time. (I never do this but have considered it) I do mostly shirts and stuff so the only window decals I cut are usually fun ones for friends who don't complain because it's free. Share this post Link to post Share on other sites
The Flaming Eyeball 0 Posted July 9 So it would appear I have the same issue as a lot of others. I was about to deep discount some 'stickers' of layered vinyl. I tried my best to get all the bubbles out from the top layer with no avail. These will be going on a vehicle, which will spend some time outside. Will the heat of the sun get rid of these tiny little annoying things? These are not a local to me install, mailed and customer installed. Both are Oracal 651. Share this post Link to post Share on other sites
Dakotagrafx 6,674 Posted July 9 No they won’t, practice will help your technique in applying without bubbles. Irrelevant you starting to apply near your registration marks and slowly working the vinyl down? Share this post Link to post Share on other sites
Wildgoose 3,746 Posted July 9 Did you try popping them with a pin? It should let you bleed the air out of the ones big enough to poke. Sometimes smallish bubbles will work out over time but not a guarantee and it looks bad when someone buys something that has bubbles before they ever even install them. Paper tape is better too, and a lot more forgiving even if a little harder to align, but it can be done fairly easy when the background color is darker like that. If I am selling to self applicators I typically put registration marks and make them install in layers. Share this post Link to post Share on other sites
The Flaming Eyeball 0 Posted July 24 As it turns out he loved them anyway. But it bothered me. What transfer tape is best? I'm using the MT80P clear type. I have some Oratape HT55, but it is not nearly as sticky, and it makes it difficult for the vinyl to come off the backing. Share this post Link to post Share on other sites
MZ SKEETER 3,932 Posted July 24 Any tape is not supposed to lift the vinyl off the backing, you squeegee the tape real good, and peel the backing away from the vinyl. It makes a huge difference. Also make sure that your not using too much force and driving the vinyl into the backing. I only use medium tack paper tape. Share this post Link to post Share on other sites
