IZZY 1 Report post Posted November 24, 2018 SOY NUEVO EN ESTO. SALUDOS. COMO PUEDO RESOLVER ESTO> MANDO UN CORTE PERO CASI AL FINALIZAR TODO HACE UN CORTE ATRAVESANDO TODO EL DISENO. ENTONCES HECHA A PERDER TODO. EL DETALLE ES QUE ANTES NO LO HACIA. Y AHORA SI. OJALA ME PUEDAN AYUDAR. EL PLOTTER ES MH 721 MK2 Y EL SOFTWARE ES SURE CUT A LOT 3 PRO. Share this post Link to post Share on other sites
Dakotagrafx 6,245 Report post Posted November 24, 2018 Scalp will make a cut thru the design after cutting if it has not been activated - activate your software should resolve this Share this post Link to post Share on other sites
IZZY 1 Report post Posted November 24, 2018 COMO LO PUEDO ACTIVAR. O DONDE Share this post Link to post Share on other sites
Dakotagrafx 6,245 Report post Posted November 24, 2018 You can activate your Sure Cuts a Lot 3 Pro software by going to the Help menu and clicking "Activate". You'll be prompted to enter your name and the serial number for the software. The serial number can be found on the Sure Cuts a Lot package near the bar code. It is a 25 digit number with dashes in it. Make sure to enter the dashes as they are required. Then click OK. The software will thank you for activating and it will no longer cut the extra lines through your jobs. If you don't own a copy of Sure Cuts A Lot 3 Pro, you can purchase it here at USCutter.com. Share this post Link to post Share on other sites
IZZY 1 Report post Posted November 24, 2018 OK. MUCHAS GRACIAS. DAKOTAGRAFX 1 Share this post Link to post Share on other sites
