2botcreation 0 Posted November 20, 2018 So im new to Flexi and im learning as I go, one issue I experience and cant figure out is: is there a way to process a print and cut design without printing? like skip the printing process and go straight to the contour stage? For example, If I have a print and cut design and I print the file successfully, and lets say i decide to cut later and shut down the program. How can i come back to the step where the software sends the cut frame to the cutter device without having to print another image Hope that made sense Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 20, 2018 open your image again in flexi and select contour cut from the drop down menu under file - it should lead you thru the process to find the marks - just tried it on my flexi cloud and worked Share this post Link to post Share on other sites
