kranker1450 3 Posted November 19, 2018 I just ordered a Titan with Vinly LTR. The question I have is how do I use 2 separate computers with the one license? If I have one computer I use to design on and one for the cutter do I have to unregister the computer I am not using then register the other one and vice versa? thanks Krank Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted November 19, 2018 Pretty much, you can only cut on 1 computer. Would it be worth it to you to buy just the CUT version for cutting $59.00 and have another license? Or maybe you can buy a 2nd license? Important! Each Software license entitles you to Activate a single computeri.e. one (1) computer (unless you have a volume-license). If you Activate multiple computers the software will report that you have Too Many Activations.* If this occurs you have two (2) options: Deactivate the other computer(s) you have Activated – then Activate your current computer. To do this simply go to each computer and Deactivate it, see How do I Deactivate. If it is not possible to Deactivate, you may request to Clear your PSN Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted November 19, 2018 Also, please refer to the FAQ for this question here: http://www.iifuture.net/faq/index.php?sid=289404&lang=en&action=artikel&cat=15&id=159&artlang=en&highlight=multiple Quote Share this post Link to post Share on other sites
kranker1450 3 Posted November 19, 2018 so as long as I only cut from the one computer I will be able to design and save on the other one without having to activate and deactivate it each time? Save it to a thumb drive. Did I read that correctly? Quote Share this post Link to post Share on other sites
