beastprints 0 Posted November 11, 2018 So I was cutting a piece of vinyl and the cut messed up and I had to pull the vinyl out because it was jammed when I went to cut the sheet again it would read it was cutting on the computer but nothing was happening with the cutter I checked the cutter and there was a blank screen I tried resetting it and it would reset display the product name as It does and go blank again I have tried everything I know to do Share this post Link to post Share on other sites
504vinyl 0 Posted April 5, 2021 I am having the same issue as you. I don't seen any updates on here but Did you figure the problem? Share this post Link to post Share on other sites
darcshadow 1,626 Posted April 5, 2021 The OP only has this one post and it's 2.5 years old, I wouldn't count on getting a reply. Share this post Link to post Share on other sites
slice&dice 2,450 Posted April 5, 2021 2 hours ago, 504vinyl said: I am having the same issue as you. I don't seen any updates on here but Did you figure the problem? Cliff it. Share this post Link to post Share on other sites
