Jp450r 1 Posted October 19, 2018 For the past couple of days my titan 3 se will just stop cutting before the job is done. i had the MH seris and the SC2 and never had this problem, Please help!!! Share this post Link to post Share on other sites
haumana 1,220 Posted October 19, 2018 What does the display say? Does your software show any errors or stalls? How large of a file are you cutting? Share this post Link to post Share on other sites
Jp450r 1 Posted October 19, 2018 The display on the cutter? How do i check the file size? Like i said in my first post, i cut the exact same things with a MH series and sc2 series cutter and this never happened. Share this post Link to post Share on other sites
haumana 1,220 Posted October 19, 2018 How long have you had the Titan? Are you making sure the that the cutter carriage doesn't hit the kill button? Has anything changed in your setup, besides just using a different cutter? Windows upgrade? Software upgrade? Relocation of equipment? etc. You did not specify that you cut the exact same design on the other machines, just that the other machines did not stop before finishing a job. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 19, 2018 Have you tried changing the connection cable? I had that happen before on my Graphtec. The USB cable, must have gotten broken. I could wiggle the USB cable and the cutter took back off again. I put a new USB cable on and it fixed the problem. Also a USB cable that is too long will create this problem. Share this post Link to post Share on other sites
Jp450r 1 Posted October 20, 2018 12 hours ago, MZ SKEETER said: Have you tried changing the connection cable? I had that happen before on my Graphtec. The USB cable, must have gotten broken. I could wiggle the USB cable and the cutter took back off again. I put a new USB cable on and it fixed the problem. Also a USB cable that is too long will create this problem. i do have a longer USB cable because of the distance between the cutter and my lap top. I had the same cable though on both of my other cutters though so i dont think its the length but i will wiggle it the next time it does it and see if thats the problem. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 20, 2018 I tried a 16 ft before and it kept stopping. No wiggling is going to fix that. It's just too long.(It was a cheap cable from Ebay) I went back to a new 12 ft and never had a problem again. ( It also was a cheap cable from Ebay) Share this post Link to post Share on other sites
Jp450r 1 Posted October 20, 2018 20 hours ago, haumana said: How long have you had the Titan? Are you making sure the that the cutter carriage doesn't hit the kill button? Has anything changed in your setup, besides just using a different cutter? Windows upgrade? Software upgrade? Relocation of equipment? etc. You did not specify that you cut the exact same design on the other machines, just that the other machines did not stop before finishing a job. Sorry i should have mention that but yes some of the stuff i cut with the others stopped with the titan. Nothing has changed but the cutter. Share this post Link to post Share on other sites
Jp450r 1 Posted October 20, 2018 7 minutes ago, MZ SKEETER said: I tried a 16 ft before and it kept stopping. No wiggling is going to fix that. It's just too long.(It was a cheap cable from Ebay) I went back to a new 12 ft and never had a problem again. ( It also was a cheap cable from Ebay) The one i have might be 6ft but no longer than that. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 20, 2018 OK, but you still might want to try a new one. Have you tried to install with a serial cable? Share this post Link to post Share on other sites
Jp450r 1 Posted October 20, 2018 12 minutes ago, MZ SKEETER said: OK, but you still might want to try a new one. Have you tried to install with a serial cable? i dont think i have the right connection on my laptop for the serial port. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 20, 2018 13 minutes ago, Jp450r said: i dont think i have the right connection on my laptop for the serial port. The Tripp-lite Keyspan Adapter is for USB ports on a laptop. Have you contacted UScutter tech support about this problem? Below is example only, Find the best price. https://www.ebay.com/itm/NEW-TRIPP-LITE-USB-Serial-Adapter-Keyspan-USA-19HS-High-Speed/302926495831?hash=item4687d38057:g:7rIAAOSwR6BbyeK8:rk:4:pf:0 Share this post Link to post Share on other sites
haumana 1,220 Posted October 20, 2018 Try a keyspan, that would be your best bet at this point. They're are a lot more consistent for data communication with the cutter. If that doesn't work, or if you happen to have one handy (and want to just give it a go) - use a powered USB hub. Share this post Link to post Share on other sites
