Guest Norm a Moore
Vinyl Master program problem
Guest Norm a Moore
Post removed as unrelated to USCutter software.
Edited by VinylMaster
Not related or customer of USCutter
Guest Future Support
If it was working before, and now it isn't, it is most likely a matter of selecting the correct port setting. When you upgrade the software, the existing driver is not affected, and remains installed in the vinyl spooler without any changes.
Another thing to check on the Roland is the emulation is set to HPGL - mode 2.
Also if it is a recent model Roland, on a USB cable, select "DirectUSB" port method and you should see it in the list of ports.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
