ahgrafx 0 Posted October 6, 2018 My SC 52" plotter is doing what seems like sloppy cuts and not finishing, leaving open cuts. no right angles they are all rounded. Share this post Link to post Share on other sites
ahgrafx 0 Posted October 6, 2018 top is the digital cut file in vinylmaster and bottom is the cut, I have upped the baud rate and it is doing nothing to change it. please help Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 6, 2018 Is this a new cutter to you? Doesn't look to be set up correctly. How did you set your blade? And what is the blade offset at? It has nothing to do with baud rate. Your baud rate should be 9600. Share this post Link to post Share on other sites
arty-rc 719 Posted October 6, 2018 Have you checked to see if the carriage wheels are in their track????? Share this post Link to post Share on other sites
haumana 1,220 Posted October 6, 2018 check offset and maybe slow the cutter down. if you can, try to vectorize the text and see what's happening with the nodes. Share this post Link to post Share on other sites
ahgrafx 0 Posted October 7, 2018 11 hours ago, MZ SKEETER said: Is this a new cutter to you? Doesn't look to be set up correctly. How did you set your blade? And what is the blade offset at? It has nothing to do with baud rate. Your baud rate should be 9600. just went to check blade offset and that is exactly what it looks like is incorrect, performing the calibration now. carriage wheels track?? my understanding is the wheels can go anywhere except where the "brackets' are located? is this not correct? not a new cutter ut this is the first time I have used it for text. the text is vector. ill let you know how the calibrations goes. Share this post Link to post Share on other sites
ahgrafx 0 Posted October 7, 2018 blade offset is currently set to 0 but none of the calibration choices looks any different, all sloppy like the photos shown. Share this post Link to post Share on other sites
ahgrafx 0 Posted October 7, 2018 the quick calibration worked, thanks mz skeeter! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 7, 2018 5 hours ago, ahgrafx said: the quick calibration worked, thanks mz skeeter! Your welcome Share this post Link to post Share on other sites
