rookerdesigns 0 Posted October 5, 2018 Hello, I have a UScutter SC2 and have been trying to learn contour cutting. But I can't get it right. Here's what happens.. After I print the design and add the registration marks. I put the sheet into my SC2 machine and begin the Auto Detection of the Marks. Only my machine doesn't detect them, it puts it into a mode that allows me to move the arrows located on top of my SC2 to move to the 4 points. After that, I click the machine autodetected fine, all though it didn't really.. So after that, I click Cut. Sometimes it traces about 2mm off on the X, so I set the offset. Then I try again, then it is all smashed the next time.. So I try to use 4 point manual. Only, I can't control the laser with the arrows on the VinylMaster Cut to and the laser never turns on. When I try to do a FULL laser calibration, this happens as well. So I only did a quick laser calibration. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 5, 2018 The SC2 does not have auto detection. It is manual laser.. You have to use the arrow buttons on each, registration mark. Sometimes putting your sheet on a carrier mat helps. Share this post Link to post Share on other sites
