crambo117
Blade Drops jogging between cuts.
hey everyone, ive had my sc34 for 3 years or so. ive always had the same problem. larger (100kb+) cuts end up dropping the blade when jogging to the next object. which cuts through and wastes tons of material.  normally i cut small simple designs, but right now im doing a 16ft trailer and cant even get a single line of words without it slicing it.
any suggestions would be great!
That cutter may not even have enough memory to do a design that large.   Also best to put on a serial cable or a Tripp-Lite Keyspan Adapter.  The SC cutter has a cheap Chinese chipset.  It is not TRUE USB like higher end cutters.   And like above,  Do you have your blade set correctly?  Tell us how you set it.
