3bbgunns 0 Posted September 5, 2018 I bought an .eps file on etsy. I am able to download it and open it in SignBlazer but when I cut its blank... is there something free to take the place of SignBlazer I should switch too? Thanks, Brandi Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 5, 2018 Try import, not open. Share this post Link to post Share on other sites
3bbgunns 0 Posted September 5, 2018 That doesn't work either... itll pull up the file but I cant get it in the box or to the cut screen. Share this post Link to post Share on other sites
haumana 1,220 Posted September 5, 2018 do you mind posting the file? not all .eps files are vector. Share this post Link to post Share on other sites
3bbgunns 0 Posted September 5, 2018 Here it is! HEARTBEAT FOOTBALL.eps Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 5, 2018 11 minutes ago, 3bbgunns said: Here it is! HEARTBEAT FOOTBALL.eps check your messages Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 5, 2018 I assume that dakota opened this file in Adobe Illustrator and saved it as a legacy version (v.8 and prior)? (and provided you with that Back_saved file) SignBlazer chokes on current versions of .eps files -- the program has not been updated in many years, so it doesn't have the code to import stuff created more recently. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 5, 2018 8 minutes ago, slice&dice said: I assume that dakota opened this file in Adobe Illustrator and saved it as a legacy version (v.8 and prior)? (and provided you with that Back_saved file) SignBlazer chokes on current versions of .eps files -- the program has not been updated in many years, so it doesn't have the code to import stuff created more recently. no tried doing it in flexi- give it a shot slice Share this post Link to post Share on other sites
darcshadow 1,625 Posted September 5, 2018 I was able to open the file with Inkscape, which is free. For a long time I would use Inkscape to create the design then copy and paste into SB to do the cutting. Not ideal but it worked. I eventually figured out how to cut straight from Inkscape, although it does not have any of the features that a true cutting program has it will get the job done. If I ever get serious about this hobby I might buy a true cutting program, till thing Inkscape and SB have served me well. Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 5, 2018 To directly answer Brandi's specific question --- IrfanView is free and can be used as a 'canopener' for these types of files and then transferred into SBE. Share this post Link to post Share on other sites
mfatty500 454 Posted September 5, 2018 open fine in CDx7 Share this post Link to post Share on other sites
