TMFWade
Titan 3 SE 53" (cuts are not lining up)
Exactly,  so why not start your own post? as this was in a Titan category thread. ...  Your new post should be in the SC category thread, that is what your having a problem with.
Hi,
my name is David and I'm from Germany.
I recently bought a Secabo T60II Cutter, which seems to be absolutely equal to the Titan 3 SE ARMS Cutter, they are just differently branded for the European and US Markets.
I just had the same problem as described in this topic. I also did a lot of tests with knife force and the pressure of the pinch roles, without improvement.
I also own a Roland CAMM-1 PNC-1000, which is at least 20 years old, where I never faced this issue.
So today I've done a test cut with my Roland CAMM-1 to compare if I can see any difference in the way both cutters do.
And what I noticed is, that my CAMM-1 always finished a cut in the X-dimension. The T60II, and I guess the Titan 3 SE ARMS too, always finishes a cut in the Y-dimension.
That's not a problem of the cutters themselves. That's a software problem.
For the CAMM-1 I'm using a different Software (Inkspace + Inkcut extension). So I've done a test with my Secabo T60II and the Inkcut software and everything is fine, because the cuts are finished in the X-dimension. And I think it's normal, that the Y-dimension is more precise than the X-Dimension. (Because of the better accuracy in the Y-dimension, the cuts line up fine when they come together over the X-dimension)
I hope you can follow me.
I will provide this feedback to Secabo and I hope that they will update their Software asap.
