RoseM 0 Posted July 29, 2018 I’m trying to weld my text so I have no overlapping cut lines in a text but apparently I’m doing something wrong! I select and weld and nothing happens! Any help is greatly appreciated! Thanks! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 29, 2018 It will only show the weld when the text is cut. Are you saying they still overlap AFTER they are cut? I don't use Signcut. No mention of which design software you are using. You should be able to weld in the design software. Share this post Link to post Share on other sites
Sue2 920 Posted July 29, 2018 Did you convert to curves first? Sue2 Share this post Link to post Share on other sites
RoseM 0 Posted July 29, 2018 48 minutes ago, MZ SKEETER said: It will only show the weld when the text is cut. Are you saying they still overlap AFTER they are cut? I don't use Signcut. No mention of which design software you are using. You should be able to weld in the design software. I’m using signcut ! Share this post Link to post Share on other sites
RoseM 0 Posted July 29, 2018 31 minutes ago, Sue2 said: Did you convert to curves first? Sue2 No I have not. I will give it a shot! Thanks! Share this post Link to post Share on other sites
RoseM 0 Posted July 29, 2018 6 minutes ago, RoseM said: No I have not. I will give it a shot! Thanks! It worked for me, thanks so much! I knew I had to be leaving something out! Share this post Link to post Share on other sites
