phil lancaster
cutter sometimes cuts a dashed cut line
most of the time we have found that a combination of too much blade exposure, bits of vinyl stuck in the blade holder and the need for a drop of oil in the blade holder is the cure for that symptom
last 3 questions
1 how are you setting your blade depth?
2 did you try a new blade to make sure you don't have a broken tip
3. is there a groove in your cut strip?
My 2-cents.
There is a tension adjustment screw you can manually access (behind the side cover which can be easily removed) and the cutter head drive belt may require some slight increase in tightness.
