hillgill 0 Posted June 30, 2018 My carrier will not move with the arrow controls. The reset button will bring the carrier back to the home position but the select and enter buttons do not work. Carrier will not move, and can not reset the spped and pressure. Help! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 30, 2018 Read the user manual, page 21. USCUTTER.com website. SUPPORT, You have to take it offline LOCAL button. The user manual explains about how to use the CONTROL PANEL. Share this post Link to post Share on other sites
slice&dice 2,450 Posted July 1, 2018 It almost sounds like the keypad itself has issues. As you mention that even the arrows Online would change the speed and pressure. Which you say it isn't doing. Possibly the physical connector/plug to the keypad is somehow dislodged slightly (allowing just the reset to work). Yeah, a bit of screw removal and taking off the top cover, check what's 'under the hood' 2 Share this post Link to post Share on other sites
hillgill 0 Posted July 1, 2018 Yes, it appears the keypad is the problem. Odd that the reset button will work though. Taking off the top cover looks a bit tricky? Have you done this before Slice&Dice? Share this post Link to post Share on other sites
