Arborist 0 Posted June 30, 2018 Hello cutters, I have a logo (a tree) that I'm trying to cut just the outer 1/4" edge or so. When using the outline tools I loose a lot of the detail. Using Vinlymaster Pro V4 Thanks in advance for your much needed help. Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 30, 2018 Can you post a screenshot or something to give us a better idea of what you are fighting? Quote Share this post Link to post Share on other sites
Arborist 0 Posted June 30, 2018 Just looking to cut the outer 5%-10% of a silhouette. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted June 30, 2018 Using the default settings it traces it fine. Then outline it 0.25" using this tool (tip change the corner style for variation): 3 Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted July 2, 2018 I'm guessing you're wanting more of an inline tool. You want the crisp sharp corners on the outside. I don't know in Vinyl Master, but in Inkscape I'd duplicate the design, add a stroke then convert the stroke to a path then merge the two images keeping only where they overlap. leaf.eps 1 Quote Share this post Link to post Share on other sites
Arborist 0 Posted July 31, 2018 Sorry for the late response guys, business has been insane and I can't find carer type employees for the life of me. VM trust me when I say I spent hours researching the tools before coming here. I find this software very instinctive and easy to use. What I'm looking to do can't be done with the module. Darc you might be on the right path my friend but I think it can be done in vinyl master. I did it with VM Pro by mistake when I first got the software. What I remember was multiple exact outlines "in blue" but it wasn't called "outline" in the program. I used the pen and drew it out on paper but I can not find the file. Is it possible to duplicate the image, resize the duplication and weld them? Thank you. Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted July 31, 2018 Duplicating and resizing can work, but not in most cases. Text and complex shapes simply scaling up the size does not give you the same results as an outline. Quote Share this post Link to post Share on other sites
Arborist 0 Posted July 31, 2018 This is what I'd like to do but with only 2 lines. multi.xcf Quote Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted July 31, 2018 17 minutes ago, Arborist said: This is what I'd like to do but with only 2 lines. Just take your oroginal vector and add an outline to it Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted July 31, 2018 A bit more research into VM, and what I call a stroke in Inkscape, VM calls a pen style. So you should be able to do in VM, what I did in Inkscape. Quote Share this post Link to post Share on other sites
dwp99 283 Posted August 1, 2018 I'm not a Vinylmaster user but, is there an option on the outline to use inline instead? That would keep the sharper detail on the outer edge. I did a quick inline in Flexi on the leaf you posted. Quote Share this post Link to post Share on other sites
