MrJoel 72 Posted June 9, 2018 Just wondering how to take a square and put a radius on the corner... seems like I did it before and was able to do all the corners at the same time but it was either a long time ago or on a different program... help me out y’all Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 9, 2018 not sure in Scalp as I never did like it much but in vinylmaster, flexi , and most other programs when you make your square you can select to round the corner or not and the radius you want .. . 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 10, 2018 Not sure about Scalp either, never did like it. But you can do it very easy in FREE inkscape. and import it. Sometimes you will need different softwares, when your go to software doesn't have all the features. Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 10, 2018 Hmmmm, there is a 'dot' in the upper right corner of a square you draw within Inkscape. Drag that handle and voila. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 10, 2018 You don't even need to drag the dot. F4 on keyboard will give you a rectangle... size it... Rx at the top of the screen is horizontal radius for corners,, Or Ry is vertical radius for corners. . Move to what you want,, all 4 corners will change. Share this post Link to post Share on other sites
GraphxNMore 282 Posted September 3, 2018 SCALP has one in the library. But to do it yourself, click the node tool. Select your node, right click, path, convert to cusp. Then move your anchors until you achieve desired result. Share this post Link to post Share on other sites
