Jolene
Can you heat press sublimated shirts?
I got asked to put numbers on jerseys, then when I got them, I noticed the package slip says sublimated fabric. Can I still heat press vinyl numbers on them or screen prints? Please help??!!!!! Thank you.
I do it but it may effect the look. I have only had a couple that you would tell most turned out ok. You will blow a lot of color out so I would use a couple pieces of butcher paper to protect top and bottom platens. New paper each shirt too. The dye will migrate into the vinyl worse than normal too so be prepared for that. There are dye block HTV but I don't stock any. Siser is semi ok with this.
